replacement brake pads
chqshaitan
Warringon
Hi Guys,
I have been researching on the forums as I want to replace the current brake pads on my bike as they are not stopping as well as they used to.
Having located a few different sets but I am unsure what exact ones to get.
I have a giant CSR hybrid 4 bike(2010).
Amazon and chainreaction links (kool stop pads)
Amazon and Chainreaction links (swiss stop pads)
can anyone suggest which ones i need? or alternatives?
BSRU
A Human Being
Swindon
They are both good just I find the kool stops produce more gunk when used in wet conditions.
The choice is kool stop salmons or swiss stop EHPs.
C
chqshaitan
Warringon
thanks for the quick reply bud, but I am unsure whether i need just the pad or the whole unit.
I am guessing since this is the first time that i have bought a replacement set, i need the complete unit and then in the future, i can simply swap the pads out?
BSRU
A Human Being
Swindon
It depends on the brake pads you have, they could be cartridge pads so only the actual pad needs replacing otherwise the whole thing, that is a pad permanently attached to the holder. Also if you have the second type you could change them for cartridge type which would require you to buy the holders as well.
