Replace stem
LocalLad
Hi guys
I think I might benefit from a slightly longer stem to increase my reach. I've been looking online and I just wanted to check I'm looking at the right bits.
I've uploaded a photo of my current stem..I think it's 100mm ( measured centre to centre ).
I think that this one on wiggle is the right one:
http://www.wiggle.co.uk/deda-zero-1-2014/
Does that seem the right one? It's a specialized diverge sport if that helps. Apart from weight, is there anything to look for?
It looks very easy to fit, just a few screws. The existing one has reference to tightening to a certain level...does it matter? I haven't got a torque wrench and don't really want to buy one.
Thanks!
simon.r
Person
Nottingham
You need to check the stem will fit your fork steerer diameter (normally 1 1/8" on modern bikes) and your handlebar diameter (normally 31.8mm). Also look at the rise of the stem (the angle).
Edit - and the height of the stem where it fits to the steerer. They're normally very similar, but you may need to add or remove a spacer or two if it's different.
Given an element of mechanical sensitivity, it's not really necessary to use a torque wrench, unless you're dealing with a carbon steerer or bar.
LocalLad
LocalLad
Great, thanks. I've just checked and it is 1 1/8" and 31.8mm, which is the same as the one I linked. Also same 6° rise.
Will grab some spacers if I need them, but not too concerned since I'm changing my position on the bike anyway, so will see.
Not sure what you meant in the last para when you said "Given an element of mechanical sensitivity"...did you mean just don't try to over tighten?
simon.r
Person
Nottingham
Basically, yes! Tighten enough to clamp things securely, but not over tight. A torque wrench is the best way to know how tight you're doing things up, but in my opinion and experience you don't need one for most bike related jobs, assuming you have a 'feel' for how tight is tight enough.
mrandmrspoves
Middle aged bald git.
Narfuk
Have a look at the front of the replacement stem as some only use 2 bolts to secure the handlebars - I would always go for 4.
You can spend a lot of money on a big name stem or a lot less on a no name one - weight will be the main difference.
steve50
Disenchanted Member
West Yorkshire
@LocalLad , that is the stem, it is only two bolt at both ends, is it any good for you?
Globalti
If you use three fingers on a standard hex key tightening to the point of discomfort you'll be OK.
