GGB_Andrew
Have a tiny cut on the tread of my Gatorskins (four months old) but have had four punctures on that tyre in the last week.
There are no other cuts in the tread. I can't believe it is the same cut that is leading to the punctures but you never know. I've also checked to see if anything sharp is protuding out inside the tyre and nothing. I'm at a lost why I'm getting the pin prick punctures on the inner tube.
Anyway, can anyone recommend a way of repair that cut on the outer tyre casing (filling it in?). It is about 3mm wide and 0.5m across?
