lothian
I took a spill on my bike that resulted in a shimmy in my back wheel. The wobble isn't excessive and I can still ride my bike. But it bothers me.
I watched a couple videos on how to straighten a warped rim, and I've searched this forum and others. The consensus for the repair seems to be: Remove excess warp then true the rim. Soooo... I removed the wheel and physically weighed into the rim to remove the worst; I then remounted it and tightened/loosened spoke nipples to pull the rim to center. This repair I've never had to do before, and to my surprise I got some good results. But just can't seem to dial it in. There's still some wiggle in the wheel.
A read a suggestion to "ride out the wobble"--presumably the wheel will true itself due to the forces at play when under load? A bike shop I contacted says "true'ing a wheel is completely different than repairing a warped rim", and the latter should simply be replaced while the former should be performed on its replacement. I don't want to buy a new rim. I just want to fix my boo-boo.
Advice? Recommendations? Is this a DIY repair, or is the repair shop correct?
