GrasB
- Nr Cambridge
I've got a drum brake which isn't performing nearly as well as it should do & had done in the past. I've taken the thing apart & cleaned it by lightly sanding the shoes & using some alcohol to clean the drum lining. After drying the whole lot out this has improved the performance a bit but not huge amounts, it's no where near as good as it was originally. What else would people recommend doing to get the brake working well?
