I'm looking to replace my drivetrain due to the chainrings looking like a pool of sharks, but there are too many options. Please help!
Currently running Tiagra Double (9 speed) and plan to keep the same set up.
I know I need a 9 speed cassette, does it have to be Tiagra or would any Shimano 9 speed be ok?
Same for chainrings? I'm assuming it's 130mm PCD so mix and match any two teeth counts, or do I have to stick to certain things?
Chains, again can I stick any 9 speed on? I see Shimano chains mostly called HGxx, what do the numbers mean?
Finally, is it worth changing front/rear/both derailleur as well or do they not wear so much?
This is why I ride fixed most of the time. I don't need to know about so many parts
