Removing Tektro brake levers?
GrumpyGregry
Here for rides.
disconnect cable at caliper end.
swing lever down as far as it goes
revealing a 4mm hex bolt which you undo
they then pull off.
attached pdf should say tektro but I'm obsessing about Techo furniture at the moment
url
  • Techo 720.pdf
Andy_R
Hard of hearing..I said Herd of Herring..oh FFS..
County Durham
There should be an expanding wedge iside the bar - disconnect the brake cable at the brakes and pull the lever as far as it will go, you should see an allen bolt inside the brake which you loosen
Edit - beaten to it!
