Removing stubborn pedals
cyberknight
I had the same problem, i took it to the LBS who had a big pedal spanner and gave it some welly !
Lanzecki
You are going the right way ? :smile: sorry, had to ask.
Apart from WD-40 and leaving it overnight, Heat applied to the crank, but that'll damage what I assume you want to keep.
If you don't want the keep the pedal remove the pedal from the axle. you then have a nice long axle to take hold of. This is what I did in a similar position, I was able to weld a 3 foot bar to the axle which gave loads of leverage to remove the offending item. I think the heat of the welder helped as well.
It went in, it'll come out, Use copper grease next time. Just don't surprise the copper when you are harvesting the grease... Umm, Think I need a rest.
alicat
Staffs
Are both stuck? Remember the left hand pedal is reverse-threaded to avoid the pedal unscrewing as you cycle.
Matthew_T
"Young and Ex-whippet"
I had a problem when I got my new commuter. It seems that holding the brakes and standing on the wrench seems to MASSIVELY damage the chain. All the pins were bent and the chain kept jamming.
I have chained it now though and managed to get the pedals off with a bit of help from my dad. They are a struggle but will come eventually.
Just remember that the threads are opposite.
ColinJ
Puzzle game procrastinator!
Or more precisely it's looking at the crank from the pedal side.
I don't understand that! :wacko:
alicat
Staffs
The left side of the bike is the near or curb side.
Another tip - secure one or both brakes with a spare toe strap. Stand on the pedal wrench. Mind your ankle bone as the pedal bolt gives way.
Davidc
Somerset UK
If a pedal's really stuck my current technique is to take the crank off, clamp it in the vice and then use a block of wood in contact with the spanner and hit that with a big hammer.
ColinJ
Not if you are in a country where they drive on the right! Or if the bike is facing oncoming traffic ..
I think that strains the transmission. If a pedal is really stuck, I rest the crank on a pile of books or timber.
BAtoo
Suffolk
Removed the pedals off my 30yr old hybrid on Sunday - worked out which thread was which, decent spanner on pedal and hit it with a hammer................................... worked well :biggrin:
Plan B - bigger hammer but didn't need it ;)
