stuee147
- north ayrshire
ok this is probably a silly question im trying to remove the pedal stems on an old bike i dont have a clue what make they are. i do know its a casset bearings in the bottom bracket i took the cover bit off the pedal stems i thort it was funny im used to removing the cover with a screw driver and then remove the nut and on with the remover tool but on this one its a alen key to remove the cover and there is no nut inside in fact with the alen bolt removed on both pedal stems i can see right the way threw. and this is where i get stuck how on earth do i get the stems off of the crank ??????
stuee
stuee
