Removing freehub body
Willd
Rugby
Got my new 10mm hex-key so thought this would be a doddle :rolleyes: It fits the new one fine, but not the one stuck on the bike, which seems to be more like 11-12mm and only has splines around part of the hole.
I'm guessing I need a different tool. The new freehub looks identical apart from this. :okay:
Ajax Bay
East Devon
Some are 11mm. What sort of freehub/hub?
Willd
Willd
Rugby
The hub is one of Felt's own. Freehub is a 9 speed Shimano one as far as I can tell, the old one doesn't have any marks on it.
Big John
The fact that the hex key fits one but not the other suggests they're different freehubs. You mention a 'new' one but haven't removed the old one yet. I always get the old one off first before sourcing a new one. There are a multitude of different freehubs. Some undo from the back, some from the front and others can simply pull off. They can all accept a Shimano cassette but are fundamentally different.
Willd
Willd
Rugby
Removed the old one - 11mm allen key from behind ^_^ As Big John foresaw, I have the wrong replacement, still it was from Amazon, so free to return. The helpful local bike shop (Not Halfords :rolleyes: who didn't even have a 11mm allen key) had 3 similar ones, but not the exact one.
I'll clean the old one up to see if it has any part numbers etc. and try contacting Felt directly.
Now just need a new freehub / hub + freehub / wheel / bike :rolleyes:
  • Like
Reactions: C R
Can you not give it (the freehub) a service. Pop the seal off the hub side and drop some oil into the freehub (frees up the pawls) and a little grease on the bearings (this is how Shimano type designed freehubs are), or others use sealed cartridge bearings and are easy to pull to bits, with the right tools.
Big John
I know freehubs aren't cheap these days and if you're prepared to devote a few hours that may end up in tears then go for it and do a service. I think everyone should do at least one so that come the next service you can run a mile and find a replacement instead of doing a DIY. There are two bearing races in bog standard freehubs which hold a shed load of animated, minute ball bearings which will need degreasing, re-greasing and finally reseated. YouTube has videos to show you what to do. They'll help but not much. It's a fiddly job. And then when it all goes back together pray the pawls work. Grease may be a bearing's friend but not a pawl's. If you have a local bike charity they'll sort you out with a freehub if you show them your old one. I think we charge around a fiver for a working used one. We've literally got a boxful and many are different. Just another component that doesn't have a standard part.
Shimano ones are a mare. Others, not so. That said, a Shimano one should work and work. Occasionally might need some grease on the hub side bearings. If starting to slip, oil poured through. I don't do any more.
Willd
Willd
Rugby
Part of the old one was retained in the hub and wouldn't come out, so in the end I gave up after trying several local bike shops and got a new Shimano wheel and freehub. New wheel was a bit wider than the original, so tyre wasn't quite as easy to fit and brakes needed a bit of adjustment. :rolleyes: Hopefully, the new freehub will last 12,000 miles too, but if it doesn't, at least it'll be easy to replace :smile:
Oh, I did get a new bike too ;) but I've decided to keep the old one for Winter when mudguards are needed.
