CrispByNature
Regular
- Somerset
Hi, wondering if you guys can help... I've recently started changing some components on my old mountain bike - including brakes, which I've swapped for hydraulics. However, even I came to take the old mechanical brakes out I discovered the brake lever is incorporated into the gear shifter, which works fine so I'm not planning to replace just yet, and it appears to be riveted into the mechanism. I can't see any joints or any obvious way in to get the lever off - any suggestions before I break it?
