Removing axle to replace for longer one
bigfella
Essex
Hi all, I have the same hub as the one pictured below. Does anyone know how I can remove the axle so I can replace it for a slightly longer one?
02GF74
both of those axles appear to have cone a locking washer so yes. you need the correct sized cone spanners - like nomal spanners but much thinner to get onto the flats.
once undone, the wholoe lots unscrews - work above a ray to catch any loose ball bearings.
note that the thread on your new axle may be different to what you have so the cones won't fit.
I tried to replace a solid axle by hollow - both looked identical but the cones would not fit the new one - a very slight difference in the thread so I gave up - wasn;t my bike so wasn't bothered.
Edinburgh
It looks like those are cartridge bearings, they have a couple of lock nuts over them. At least that is how it is on both my fixies and they look the same as the one on the left. The one on the right could be cone.
I needed to do this as well when I was building the hack fixie.
Rest the axle end up on the flanges supported by a few layers of cloth so you don't scratch them and gently tap the end of the axle, the bearings on the bottom will come out. Turn over and repeat.
You will notice that the axle is not threaded for the length, but contains smooth bits and flanges for seating the bearings. Try to find a longer axle with the same internal dimesions, just longer threaded ends.
Putting the bearings back on is best done by loosly fitting and then gently tightening the lock nuts to bring it all together.
