AndyRM
XOXO
- North Shields
I have been stripping my written off bike so that I can hang the frame on the wall as a) it's a frame I have loved and ridden since I first started out on my road biking adventures and b) it's a reminder that I'm a lucky chap.
There are just two pieces I need to remove. The first is a carbon seatpost which is stuck into the aluminium frame. I plan to remove this with lubricant, brute strength and ignorance. Though if anyone has any better ideas/tips, I'm all ears.
The more problematic piece I need to get off is the drive side crank and (what I think are called) cups on the bottom bracket. I took the left crank off no bother, and have now been left with the right side which is attached to the axle. When I try to slide the piece through the BB it sticks about an inch from the end, where the machining seems to be for the opposing crank.
Also still attached are the 'cups' on each side. I have been using the correct tool in my efforts to loosen them, and going against the 'tighten' indication which I thought would be the right idea. No joy as yet, so any advice would be much appreciated.
This is my first attempt at fully stripping down a bike and I've enjoyed the experience. I've learned a lot in the process and any advice to get me over these final two hurdles will be much appreciated.
