Folks, I have a very rough rear wheel and the bearings are defo shot, however its not quite so easy as to just knock them out from the other end as there is an internal diameter same as the bearing running through the centre. Now I might have a bearing puller at work but that is also quite heavy as its a slide hammer type, so slugging that back in the bike is something I`d rather not do
. So does any other forum member done a similar job, could they even give me a clue to a tool i could even cobble togethor? I more or less need to prise the bearings out??
