I’ve bought a fancy bike with very expensive carbon wheels. I’ve noticed that on the stand the front wheel spins for a very short time compare to all my other bikes. The brakes aren’t rubbing and the wheels are through axle. Ive had a quick peek at the bearing on the front wheel it’s a sealed bearing and packed with grease and certainly its not as loose as other bearings I’ve had. That said it’s new and completely smooth.
Is how long the wheels spins when not under load relevant does this translate to drag on the road when under load? Will the bearings loosen up over time, the bike has only done 60 miles so far?
