Reduce float on an SPD pedal
I've been using the shimano M520 mtb spd pedals with specialized mtb shoes. I have no problem clipping in and out, but what annoys me is the float movement of the shoes, specially the right one.
My left foot is locked with almost no float, keeping the ankle straight, which is great (no pain or discomfort) but the right foot tends to rotate (something to do with my natural foot alignment, toe-in) I try to keep it straight however I find myself turning the pedals with my ankle pointing out and that causes a bit of discomfort. It stops after I straight it back and ride for a few minutes..
What I'd like to achieve is to set the rotational range. I know pretty much the best position for my cleat and shoe... I just need to find a way of keeping it in that position..
Is there a way to reduce float on an SPD pedal, through adjustment or cleat type?
oldfatfool
Increase the tension on the release spring. However if you are cack footed then you will have to ensure your cleat is adjusted to hold your foot at an angle giving correct knee allignment. Forcing yourself to hold your ankle 'straight' is probably what is causing your pain. I have a bow leg from a break that means I have to ride with my heel brushing the cranks to get a correct knee movement, to allow this I use Frog pedals that give iirc 30 deg of free float, whilst this does feel weird at first, free float means your foot angle finds its natural (correct) position throughout the pedal stroke.
On my std spd pedals it took me an age to find a good cleat position, and I only tend to do less than 100k rides using them.
rockyraccoon
I always thought that the float was not adjustable on those pedals and it was to only make it easier or more difficult to release.. I didn't know I can opt for a more or less secure feel... I'll try that!
Cheers!
