Recumbent bike gearing setup for hills
28f - 32 r on 20" wheels gives 17.4 inches or 4.1 mph at 80rpm
it beats walking ( only just ) you could go lower but.................................
BTW I am using this as bottom gear on a "e-trike"
regards emma
fatjel
West Wales
38f 36r on 26” wheels on the Bacchetta which is a bit high sometimes
24f 32r on 20” wheels on the trike which is low enough
A bent trike with a 54/38 double on a Schlumpf HSD at the front and a 21 tooth sprocket on a Rohloff built into a 20" wheel at the back.
9.4" to 176.2" or 1.8 mph to 50 mph.
Mines setup for hills both ways ....... :laugh:
On a recumbent trike it gets easier as the gears get lower, but only if you don't lose your top +100" gears
28x32 bottom gear with a 700c rear wheel. If I stay reasonably fit it can get me up anything round here, though I haven't attempted a rather sporting 25% gradient a few miles up the road since I stopped riding uprights and nor do I intend to.
flake99please
We all scream for ice cream
Edinburgh
34/16 Schlumpf HSD & Rohloff on 20” wheels. Plenty low enough when fully loaded up going up hills, and more fast enough when coming back down.
byegad
NE England
My AZUB-4 had a front triple, rear 3 speed hub and a 9 speed rear cluster. (AKA SRam Dual Drive) So 81 ratios in all. Low was 15" which was as low as I could go and still retain my balance. Top was 150" and rarely used! The odd time I managed to get into gear 81, I was still spinning comfortably at >50mph. Down hill of course.
fatjel
West Wales
On my two wheeled Bacchetta I initially couldn’t stay upright below 10 mph.
Time and miles have helped to get that down to about 5mph but still can’t go as slowly as an upright so super low gears are not used much for now.
The trike is different entirely no risk of falling off no matter how slow you go
byegad
NE England
I took a couple of months to get my balance sorted on the AZUB*. I could keep it upright at 3mph in the end but if I once stopped on a hill, restarting was an absolute nightmare!
*I later found out I had a mild balance issue brewing, which is why I ride three wheels now.
byegad
NE England
That gels with my findings that 15" was as low as you can go. I run a 12" bottom gear on one of my trikes and that is no faster than I could walk on a hill, GPS hovers around 2.5mph in full climb mode. Given pushing a recumbent trike is a back breaking job I never get off. The steeper the hill the more often I stop to get my breath back, and I have tackled 33% hills on that trike.
I've done +25% hills on my trike and without a full camping load, they are easy as long as I've traction ...... ^_^
It's the main reason I geared it right down to 9.4".
One a trike, the limiting factor becomes the amount of friction you have between your wheel/s and the road not the steepness of the slope.
So once the road conditions get bad so your wheel/s start to slip, only then do you stop climbing.
