Recharging Airzound
Ellis456
Dartford, Kent
I've tried with a hand pump and take so much time, then when you disconnect some leaks out then I stick a pressure guage on it again that loses some of the air, so I tried a foot pump for a car and that did it to 7.3 psi but I had to hold the end on really hard as it would have shot off.
I even tired a garage pump and that didnt work at all, it just didnt detect the pressure in it and it only went up to about 4psi.
Any tips?, thanks.
ianrauk
Tattooed Beat Messiah
Rides Ti2
Get a track pump and don't use a pressure gauge.
Little yellow Brompton
A dark destroyer of biscuits!
Bridgend
Any tips?, thanks.
Don't bother, if you have time to use the airzound then you didn't need to use it. Once I realised that it was either airzound or brakes and if I didn't need the brakes then there was no need for the airzound I took it off , it's gathering dust in the garage.
Mine refills easily with either my track pump or my Topeak Road Morph pump, no leaking from the valve on mine as it can keep at full pressure all day.
The Road Morph and track pump can easily get to the 80 psi the horn needs to work at full blast, a locking lever on the pump heads keeps them from popping off at high pressures.
Regarding braking and using the Aizound, for me it isn't one or the other. I simply have it set up on the left hand side of the bars where my rear brake lever is situated. The rear brake is no use in an emergency stop as weight transfer will take all the weight off of the rear wheel and it will just skid under heavy braking. Likewise all the wight is put on the front wheel so I always brake from there when I need to slow down fast, this means I can have the left hand on the horn and the right hand on the drop or cross brake lever and have as much stopping power as I can get in any instance. I would only need to use the rear on a long descent to keep the rims cool or if there is a real chance of a front wheel skid (icey,snowy weather).
Although I can see the need to have both hands ready for the brakes, just use discretion in situations where you feel you may need it or where it is unsafe to use it (i.e use it when you need to let someone know you're there but not when heading for the bonnet of a car at full whack!)
John90
London
You emergency stop and airzound at the same time???? Respect.
I thought the textbook emergency stop is rear first followed almost immediately by front. Too much front = uncontrollable front wheel skid.
Personally I haven't even used the tinkly little bell that seems to come as standard these days. Can't see the point when I can shout louder.
BSRU
A Human Being
Swindon
www.airzound.co.uk explains how to setup the airzound to allow braking and using the airzound at the same time.
I use it more for waking up drivers than anything else.
byegad
NE England
+1 with the Zound in the right place. I find I rarely use mine but, on the odd occasion when I do, it's a lot louder than my voice.
