cooldiscretion
Regular
- Seattle
A couple years ago, I managed to get my hands on a vintage 1961 Legnano road bike that looks very similar to the Roma Olimpiade. The frame itself is in pretty good shape and is completely chrome. The only damage is on the chain stays from what I believe is the result of someone clamping a kickstand much tighter then it should have been. I'm not entirely certain if it's worth repairing since I've had someone at a shop inspect it and he said it isn't compromising the integrity of the frame structurally. Regardless of that, I would really like to rebuild this bike using a modern SRAM Force group set to make it more practical. I've done this before with an older steel Chesini Arena and it turned out wonderfully. I'm sorry, I know there are probably loads of vintage purists that this would anger but I am in love with the vintage frame and yet want something with all the bells and whistles of a modern group set. Anyway, I have most all the parts I need for the build excluding the group set. I've had the rear bars on the bike professionally bent to the correct width (can't remember if that's 120mm or 130mm).
Here are the parts I have had my eyes on. If someone sees anything that might cause me problems can they mention that. I know with these older restorations, compatibility problems seem to pop up with everything.
1. SRAM Force 22 Crankset BB30 50/34t 170mm GXP
2. Truvativ/SRAM GXP Bottom Bracket 70mm Italian threaded
3. SRAM Force 22 Shifters 11spd
4. SRAM Force 22 Rear Derailleur Mid Cage 11spd
5. SRAM Force 22 Front Derailleur Braze On (I will have to buy a clamp as well.)
6. Shimano BR-7800 Brake set (I've always thought these were beautiful)
7. SRAM PC-1170 Chain 11spd
8. SRAM PG-1170 Cassette 11-32t
A few things I'm not sure I'll have problems with are regarding the fact that this is 11speed which is definitely pushing it for a frame from 1961. The Chesini I built a couple years back was with a SRAM Apex 10spd groupset and that seemed to work okay. Also, I did a little reading about the BB30 bottom brackets and I don't think that's actually compatible with this vintage frame.
