Reasonably priced Dynamo
toffee
Just been looking for a reasonably priced dynamo for for a disc braked front hub - 6 hole
Found some cheap ones but want something a bit more, hopefully, reliable.
Anyone got any ideas?
glasgowcyclist
Charming but somewhat feckless
Scotland
Can you define what reasonably priced means for you?
Reliable ones are Busch & Muller, Schmidt or Shimano. What's your budget?
toffee
toffee
What did you find that you don't think is reliable?
Just applying the usual logic that some which costs £25 is not going to last as long as something that's 4 times the price, given the same circumstances.
cosmicbike
Perhaps This One.....
Egham
I've had a bit of a search as I was planning dynamo lighting for the commuter which has a disc hub. Best I found price wise was about £80 from Taylor in Germany via Ebay. Not yet bought one mind, so can't comment on quality.
mjr
The one we got from them seems fine. Rim braked.
si_c
Wirral
Rose (or German stores in general) is usually the best place to look for dynamos. Something like this - https://www.rosebikes.co.uk/article/shimano-deore-lx-dh-t675-disc-hub-dynamo/aid:591997
Unfortunately all the Shimano ones are centre-lock so you would need an adaptor.
Spa Cyles have a SP PD-8 for £70 + postage which is 6 bolt - https://www.spacycles.co.uk/m2b0s133p3037/SP-DYNAMO-PD-8-Disc
I've got the Shutter Precision PD-8, which is a 6 bolt QR dynamo hub. And I got it from Spa.
Cannot recommend it highly enough, it's very lightweight, well constructed, and looks really nice too. Seems reliable enough, got through the last winter without a single problem, still running super smooth, don't notice it when it's running the lights. Big thumbs up from me.
toffee
toffee
Yes I've noticed all the latest shimano ones are centre lock, which provoked my original question. Anyone used an adapter to convert a centre lock to 6-hole disc?
I have also seen the PD-8 but actually thought they were only 1.5 watt. Checking the LEDs again I see that they are 3 watt which I want as it will be used to charge a battery.
toffee
toffee
That's good to hear- thanks
