andytheflyer
- South Cheshire
Hi,
A couple of weeks ago I changed the 2 yo 2500 mile Shimano Tiagra gearset (HG50) chain, jockey wheels and cassette (9 spd) on my Defy 2.5 with identical parts - but the jockey wheels are Tacxx - and they are for Shimano 9 spd. I also changed the rear mech cable (complete) for a Clarke Professional (Teflon lined). The old chain was shot. Chainwheels etc are fine.
No problem - all went together Ok and I followed the standard practice in adjusting the cable tension to get the indexing to work properly. Easy-peasy.
Now for the problem - on the old (original) setup I almost never had to adjust the cable tension, today I had to do it 3 times in 40 miles. I did think at one point that the cable was slipping through the clamp on the mech - but the pinch bolt's about as tight as I'd want to make it.
So, not sure whats's going on. I can ride for maybe 1/2 an hour with no problem, silky smooth changes, total silence, then for no apparent reason the chain changes down (next larger sprocket) and then back again - flip-flopping between 2 cogs for maybe a minute - but if I increase the cable tension maybe 1/4 turn that cures it - but that's the wrong way surely? The chain and cassette are spotless, no tight links and I used a new 9spd Powerlink when I fitted the new chain.
So, I'm confused. I know new cables stretch, but this seems much more than I'd expect.
Watching a couple of vids in Youtube I got the impression that a couple of turns of the adjuster would be needed to get the chain to change cogs - mine's far more sensitive than that - 1/4 turn is all it needs. So out on a ride if the chains jumps between cogs it only needs a very small tension adjustment. But surely not every hour?
I'd dearly love to get back to a nice smooth ride - not a smooth ride for 1/2 an hour followed by a minute of total and clattery chaos!
Anybody got any bright ideas?
Thanks
Andy
Thanks
Andy
