rear mech hanger
screenman
The tool, unless the hanger is broken or bent beyond repairable.
ayceejay
ayceejay
Rural Quebec
Please stop there guys or before long I will be adding an extension to accommodate all this new stuff.
BTW would either of you care to explain your reasoning that would be really useful?
mrandmrspoves
Middle aged bald git.
Narfuk
I would buy both because I love tools - so any excuse!
If I was trying to justify the expenditure to my wife, I would explain that I would get a new gear hanger and fit it to the bike and keep the bent one as a spare once I had realigned it using the hanger tool. A damaged hanger that is a few mm out of alignment is enough to make it impossible to index the gears correctly - so if I have trouble indexing gears I always check alignment and have found it to be the cause of the problem on a few occasions (I service bikes for lots of people) The tool has always enabled me to sort the problem. When I still rode an upwrong, I had a Claud Butler Dalesman which had suffered from a rear derailleur failure and the mech had got thrown into the wheel causing the rear dropout and hanger to bend as it did not have a separate aluminium replaceable hanger. The bike would have been useless if I had not been able to realign the hanger.
Ian H
Ancient randonneur
The tool is for non-replaceable hangers, usually on steel frames. If it's a replaceable, probably alloy, hanger then a new one is the best option...assuming of course you can find the right pattern.
What Ian H says. Hanger tools are for steel. Not alloy hangers. If those get bent, get new.
slowmotion
Quite dreadful
lost somewhere
Just buy a new hanger. There are lots of generics/copies that work well and don't cost quite as much as the official replacement. Google is your friend.
