deano69
- kent ( Garden of England )
I bought a new mech hanger from cycles uk yesterday as mine is bent slightly, the one I bought looks the same ( original to the left new one to right ) but on installing it the rear mech's b-tension screw has to be wound all the way in to just get the top jockey wheel clearing the cassette cogs.
Although its working it isn't right so I added an old hi / lo screw which is same thread but 4 or 5mm longer than the stock screw but I cant help thinking its the wrong hanger as there are many variants of these hangers very similar to look at but cant seem to track down the correct one ?
In the 2nd pic I have drawn in black pen where the bottom right of the hanger needs to be so the screw does its job sitting against the bottom step without only just working having to be screwed all the way home like it is at present.
The bike its off is an old 05 Viking Targa Dx mountain bike but tracking down any parts for these is not happening at all.
You maybe thinking well if its working whats the worry but as the mechs tension spring wears over time there will be a day when the adjustment on the screw is no more.
Thanks for looking,
Deano
Thanks for looking,
Deano
as you can see from the drop out arch in the pic, I had to remove hanger to allow wheel to drop out.
