TE="atrick, post: 3323471, member: 19812"]Just bought the bag, it has a facility to hang a rear light on. Problem is the light just hangs instead of being erect. Apart from Viagra, any other tips to stop it pointing down. My rear light is a very common cheap 'push the clip and slide off' led type.
Cheers[/QUOTE]
I've a different bag but a couple of thin cable ties work for me
Only snag is you have to cut them to remove the light/replace batteries. Plus is it stops the light jettisoning itself over bumps which happened before, luckily the light survived.
