Rear light mounts
compo
Harlow
I wish that the manufacturers of rear LED lamps would make a bracket that will allow the lamp to be fitted upright or on it's side. To use the lamp in an upright orientation you can only use a vertical tube such as the seat post.
I'm not sure 100% what you mean but the Blackburn Mars brackets (I'm pretty sure others will too) can be rotated round to allow the led to be fitted upright or horizontal :wacko:
Edit: Thinking about it my previous Cateye brackets let you do that too :wacko:
compo
compo
Harlow
I guess it's down to you get what you pay for! Nicely engineered brackets wouldn't be cost effective with cheap lights.
Globalti
Manufacturers are getting better at this, I've seen lights that are attached to the bracket by a square connector that can work in any of four orientations.
Davidc
Somerset UK
They're getting better but still not good on this.
All my battery rear lights are now Smarts, either the older ones with 1/2w rated LEDs or the Lunar R1 1w rated LED. The lights are good but the brackets are (rap.
If you do mount them on a horizontal bit of rack or even on a seat stay (which is also non-vertical) then you need to do something to stop the light falling out of the bracket.
gaz
Cycle Camera TV
South Croydon
When I bought my dinotte 400r it came with around 20 different mounts. Considering it cost $150 i didn't expect any less.
compo
compo
Harlow
I didn't realise when I made the OP there were so many different mounts. My rear rack does not have a reflector bracket but there is a mount for Smart lights that will bolt onto the rack http://www.chainreactioncycles.com/Models.aspx?ModelID=29392. I can either drill the rack or, and my preferred method, is to cut and drill a plate to go behind the bracket to secure it to the rack. I have two sections of rack welded together where the bracket mounts and this will give me a surface that isn't round to butt up against.
Davidc
Somerset UK
Thanks for that link compo. I think that might be adaptable to solving what I've wanted to do for some time, which is mount a Smart below the dynamo Toplight unit in the centre of the rack
Kookas
Exeter
Moon Comets can be put in any direction and swivelled up & down, too. Not to mention they're just generally all-round great rears, and only cost £20. Love them.
Also, they don't suck in the wet like Smart lights.
Davidc
Somerset UK
With sensible use Smart lights will run underwater for 2 days. One of mine did. That was the result of a failed bracket.
They're the best (equal) I've come across in the wet - but I do put a smear of silicone grease on the seals, as I do with every electrical item used outdoors.
I've just bought a Blackburn 4, 'cos it was cheaper than a Smart with the same nominal power. I'm hoping its clip & bracket will be better than the Smart ones. (The light I'm replacing had the clip break off when I was taking it off after parking the bike, and I don't think that should happen to a light that's only 4 years old. The business end is still OK though so it may find use as a Christmas decoration.)
Kookas
Exeter
My last Smart died after the first wet ride. The one before that snapped off like yours did, as I was taking it off. The Comet has a mount similar to Lezyne's, in that it's a simple rubber strap, and feels quite secure.
Blackburn might be quite good, though - the mount on my Atom SL3.0 cyclometer is decent, but obviously that might not speak for their lights.
Davidc
Somerset UK
Smarts need a smear of silicone grease to keep them watertight - then...
I had a bracket fail where the clamping screw attaches. I might have overtightened it but don't think so. The whole lot came off and went in the Bridgwater and Taunton canal, sank, and went on flashing on the bottom for 2 days! The latest one to break was the first I bought just over 4 years ago, so it has lasted a while, but not long enough.
