NickNick
I'm having real problems with my rear caliper (Tiagra dual pivot), for the last couple of weeks I will set the alignment using the screw, get it all centred properly and without fail by the time I get home one of the pads is against the rim and the other is miles off.
I've tried loosening the mounting bolt, realigning and the mounting bolt is as tight as it will go so I don't think its shifting about on the bolt (I've checked a number of times after its gone out of alignment and the nut is still rock solid).
I then thought maybe the alignment screw isn't staying in place, so I marked it up on the caliper with a fine point sharpie went for a ride and whilst the caliper was out of alignment the screw hadn't moved.
The only thing I can think of is its something to do with the brake cable outer. The frame is a Specialized Allez (from the Zert insert era) that I put together myself about a month or two ago. The outer is router round the left hand side but the bit of the caliper that the outer goes into points towards the right, could this have anything to do with it?
e2a: will get a photo up of it in the next hour or so when I can get to the camera.
