arallsopp
Post of The Year 2009 winner
- Bromley, Kent
SOLVED: Rear disc brake rubs when pedalling hard.
Howdo.
This week's odd noise coming from the bent originates in the rear disc rotor, rubbing on the pads when I'm pedalling hard. Hard as in high power, low cadence.
It was pretty minor originally, but now develops in every gear, as soon as I hit an incline.
On a DF. I'd say you'd trigger it as soon as you get out of the saddle.
Rear wheel looks tight in the stays, so a bit stumped as to how I might fix it. I tried loosening the brake off (it looks aligned L/R correctly) but it didn't fix it even when I had pretty much no brakes!
There's a lot of flex somewhere in the system, but I'm not sure where to start...
Cheers in advance for anything you can offer.
Howdo.
