Rear derailleur
TAV
mountainash
Hi I've got a tiagra 9 speed long cage but the jockey wheel is to close to the cassette I've adjusted the b screw all the way. I've got a 32 cassette on the back which is new do I need a mountain bike derailleur?
Mike_P
Harrogate
Likely to be a bent derailleur hanger - you need the right one for the bike. Have a look at
https://www.mountainbikecomponents.co.uk/product-category/derailleur-hangers/
Spiderweb
Not So Special One
North Yorkshire
I have a Deore LX rear mech on my CX bike and had to buy a longer B screw to run a 36t cassette.
You could try this or get a rear derailleur extender link (link below but cheaper ones available on eBay;
https://www.merlincycles.com/sunrac..._medium=Affiliates&utm_campaign=genieshopping
  • Like
Reactions: TAV
chris-suffolk
I run a 105 long cage with a 34 rear sprocket, and it's fine. I'm guessing the geometry of Tiagra is the same as 105, so it should work.
TAV
TAV
mountainash
I thought so aswell but like I said the jockey wheel cage is touching the cassette and the b screw is fully extended. Some guy told me to buy a larger b screw.
chris-suffolk
I've read that you can put the 'B' screw in backwards. Can be a bit fiddly to turn (long nose pliers) but you should only have to do it once.
