Rear Derailleur for touring
Jon62
south west
Hi,
I currently have a Shimano Alivio RD-400 9 speed, it is not working too well at the moment, so i am planning on upgrading.
So what would be a good choice?
I have a 44/32/22 Chain rings and a 12-36 cassette.
Advice welcomed!
roubaixtuesday
self serving virtue signaller
My advice FWIW.
0. Check*
1. Replace cable. Check.
2. Replace cable outers. Check.
3. Replace chain and jockey wheels. Check.
4. Replace and/or realign gear hanger. Check.
5. Consider replacing derailleur.
*Check using https://www.parktool.com/en-int/blog/repair-help/rear-derailleur-adjustment
Might be worth specifying what exactly are your symptoms of "not working too well"
Dérailleur is probably the least likely source of whatever your issue is IME.
I like Skol
A Minging Manc...
My advice FWIW.
0. Check*
What he said ^^^
Wot they said ^^^.
I would just add, before replacing cable maybe clean and lube. Derailleurs rarely wear to the point of requiring replacement. Quality cables that are not frayed/kinked rarely need replacing.
Big John
We use a lot of Alivio stuff where I work as a volunteer. It's not top of the range, as you're aware, but it usually does the job pretty well. What makes you say it's not working too well? A number of things in the overall drive train can cause issues, even a tight link as I discovered the other week, so buying a new rear mech might be jumping the gun a bit. If you haven't got a hanger alignment tool your LBS might not charge much for a quick check and if it's properly aligned you can eliminate this from your 'check' list. They'll align it for you if it is out of line.
I like Skol
A Minging Manc...
I have ordered an alignment tool, and will keep you informed of the outcome.
No alignment tool required. A straight edge across the hanger with rim measurements taken at 90 degrees is all that is needed. I usually use an old spirit level as the straight edge.
Cycleops
Accra, Ghana
That’s interesting. Could you elaborate a bit as I can’t quite work out the method?
DCBassman
My advice FWIW.
0. Check*
Agree, and Alivio RDs are pretty bombproof.
Jon62
Jon62
south west
Well,it was none of the above, after putting the bike on the stand and rotating the pedal i noticed the cassette was wobbling, so out with the wheel and check the lock ring, that was not loose, so off with the cassette to find the spacer i had used was not the right thing for the job, quick trip to the local cycle shop and problem sorted.^_^
