Deleted member 35268
Can I assume that the spring that is housed in the rear derailleur barrel adjuster actually helps with the cable tension.
I lost the damn thing whilst replacing the cable!
Basically, my smaller cogs are jumping, despite adjustments (two evenings after two rides)
And, what does the (B-Tension) screw do that pushes against the frame actually do - it never seems to make much difference however I adjust it.
Perhaps the Shift Shock mentioned in the manual is what I am getting where it jumps gears
https://si.shimano.com/pdfs/dm/DM-RD0003-09-ENG.pdf
Shimano 11 speed tiagra btw
