Ok, it's my first bike with internal cabling so sorry if it's a newb question...
I'm building up a synapse alloy frame with internal cabling, all fine until I got to the rear brake. It's all connected now but the lever has more friction than I'd like and I can hear a faint rubbing sound. The brake return is fine and the cable outers were cut with proper snips and the ends lovingly dremelled to perfection.
My fear is, as the cable is naked as it were in the frame that it is sawing away at it in some hidden rub location - am I being paranoid? Is the rubbing just a resonant sound from the cables running throughout the outer?
It did have a big old length of plastic liner through the two ports for the rear cable, really handy for installation, that was to be taken out after the cable went through right!???
I suppose I could trim the liner done and run that accross the naked section?
Any advice would be massively appreciated (even if it's stop worrying you tart).
