I am given to understand that there is a bicycle component called a Pingf*ckit, but I'm not sure what it is.
Don't get me started. I'm not fixing my bike because the part I removed last time I thought I had time to fix it has disappeared now I actually do have time to fix it.I think you mean you don't know where it is.
Go see John 'The Seatpost Man' in Chorley (http://www.theseatpostman.com/home) - he will extract it no problem and no damage to bikeTitanium seatpost in aluminium frame without taking anti-corrosion measures error!
What is really annoying is that I knew about the risk and had been thinking that I really ought to take preventative measures. It was ok when I checked it a few months ago but now it is stuck solid!
I don't want to risk damaging the post or frame so if some moderate thermal stressing doesn't break the bond then I will leave the post where it is. I have done thousands of miles with the current saddle height without problems, but noticed that it is a couple of mm lower than on my other bikes which feel subtly better.
Thanks. If the post's position were way out, I would probably go for that but it is definitely close to its optimum position. I have been using it in the current position without problems but I just wanted to adjust it slightly to see how it felt. If I can shift it without risking causing damage then I will, otherwise I will leave it where it is.Go see John 'The Seatpost Man' in Chorley (http://www.theseatpostman.com/home) - he will extract it no problem and no damage to bike
Actually, some temporary padding would be a simple way to find out if I actually do want to raise my saddle slightly - I'll give that a go!![]()
True ...Colin , some saddles are a bit higher than others ...
... but I have just bought 3 more Planet X saddles so all my bikes can have the same type!... so perhaps try another saddle and leave the post as is.
The Rinsten Spring, cannot believe anyone thought of this sooner.
Remove the clamp, you no longer need it - think of the weight saving.
