No danger should be easy enough. when rebuilding try to get the cross cable (not the correct term ) as straight as you can as the straighter the better the brakes.
You can get the cable straight by either fitting MTB blocks or even by longer bolts and a few washers or spacers between the brake blocks and the caliper.
