DRM
- West Yorks
Being part way through resuscitating an elderly Raleigh MTB, from around 1990, into a Hybrid/Hack type bike, I will have to remove the cranks and strip, clean & grease the cup & cone bottom bracket, which has loads of play in it, my question is, if the BB has had it, will this be an English threaded BB ? would I be better off replacing it with a cartridge type, square taper? I haven't got the cranks off yet, so I have no idea what length the axle is.
I'm not sure what model of Raleigh it is, as there is no stickers on the frame for the model, just on the down tube, with Raleigh-Special Edition, but the closest I can see on line is the Nitro, which seems to be the same geometry with the rear brake cable internally routed through the top tube, however all the pictures of Nitro's are finished in a dark metallic red, this thing is finished in a dark metallic green, if anyone knows what it is I'd be glad to know, all I know is it's nothing fancy, it's quite heavy!
