Raleigh Airlite 100, ideal first road bike or winter trainer
Comes fitted with SKS mudguards and selle italia Gel saddle.The bike is pictured with a saddle pack fitted which is not included, The pedals will be replaced with flat road pedals however the SKS mudguards, the selle italia gel saddle and the bottle cage will remain with the bike.
The bike does have a couple of minor age related marks and a slight tear in the bar tape, if you wish for me to purchase new tape on your behalf(at the buyers expense) and fit it before you collect then that would be no problem.Other than that its in great condition and looks really good.
spec is as follows:
Style: Gents 700c Racing
Wheel size: 700c
Frame size(s): 55cm top tube
Min. inside leg: 28.5" (72cm) recommended
Colour: Blue
Frame: Airlite 7005 aluminium compact road design
Forks: Chromoly aero blade
Gears: 21
Gears rear: Shimano 2200
Gears front: Shimano
Gear shifters: Shimano STI 21 speed dual control brake/gear levers
Chainset: Lightweight alloy crank arms
Bottom bracket: Semi-sealed cartridge
Freewheel: 7 speed
Headset: Semi integrated A-head system
Stem: A-head
Handlebars: Alloy racing
Brake front: Tektro alloy caliper
Brake rear: Tektro alloy caliper
Brake levers: Shimano STI 21 speed dual control brake/gear levers
Rims: Mach1 CFX alloy
Hub front: Alloy, quick release
Hub rear: Alloy, quick release
Tyres: Hutchinson Flash, blue line
Saddle: Selle italia gel
Seatpost: Alloy micro-adjust with alloy seat clamp
I can box so as you can arrange a courier(around my shifts) or i can courier for £29.
£175
spec is as follows:
Wheel size: 700c
Colour: Blue
Gears: 21
Freewheel: 7 speed
Stem: A-head
£175
