TeeJay3000
Hello folks,
I bought a Saracen Levarg last week from an online retailer that was sold as new/unused. I don't have much of a clue with bikes (this is the first I've owned in a decade) so I had it serviced at an LBS after arrival and they confirmed it was good to go. While cruising about earlier today, I clipped a low, solid obstruction at the side of the road while turning at less than 10mph - the right pedal and my right leg took the initial blow (ankles sure can bleed!). The bike bounced a few times against the obstruction as I regained control so I gave it a once over at home to check for any other damage.
On the top and sides of the right chainstay, I found what I would describe as a patched/raised area with a uniform edge all the way around. I'd estimate it's about 3/4 of the length of the chainstay (centred and not touching the ends) The pictures aren't the best as it's difficult to focus a camera on the raised area exactly but the lines on either side appear to be straight and the ends (crossing over the top) are neat. There's also some paint chipping nearby but this bike's coat chips easily.
I'm going to assume that no blow to a bike could cause this, so is it by design or an indicator that the bike has been professionally repaired in the past? I may hassle the retailer for a partial refund if an 'as new' bike has been crashed by someone else.
Grateful for any views!
