No figured out Its like a sram type..so 8mm inner bolt pushes on outer..
Levo-Lon Guru 22 Dec 2015 #1 No figured out Its like a sram type..so 8mm inner bolt pushes on outer.. Last edited: 22 Dec 2015
OP OP Levo-Lon Guru 22 Dec 2015 #3 the 8mm inner bolt seems very tight indeed.. Last edited: 22 Dec 2015
lpretro1 Guest 23 Dec 2015 #4 meta lon said: the 8mm inner bolt seems very tight indeed.. Click to expand... It's meant to be or your crank would drop off. More effort needed
