Just FYI and YMMV, but I took the Icetec rotors off my best Ultegra bike and fitted lower spec standard ones (SLX MTB ones I think from memory) because the ICE ones would always warp when hot and then rub for a few 100 yards until they cooled down again. No amount of caliper adjustment could stop it and I just gave up in the end.
My pseudo-science head suggests this is an obvious side effect of the construction as I believe it is a layer of ali sandwiched between the two steel outer surfaces. The reasoning is less weight(?) and better thermal transfer by the ali to the cooling fins, but my theory is that sandwiching the metals with differing thermal expansion properties causes massive internal tensions as the metals heal and cool, and it is this that leads to the warping when hot.
I'll stick with my plain steel rotors thank you.
