mancbike
The rear wheel on bike needs truing (quite badly) so thought I would have a go.
But firstly:
I have taken out all the tension from the spokes. As I rotate the wheel it is quite a bit out both radially and laterally. Therefore if it is out of true without tension can it be brought into true with tension. IE is it worth bothering with or should I just get a new wheel?
But firstly:
