Quick release disc wheel removal
mstaves
Hi.
I'm trying to remove the front wheel from my son's ridgeback nemesis.
Its a quick release wheel and I've got the spindle undone but the brakes and cables are still attached.
As it's a quick release wheel, I'm thinking I shouldn't need tools to remove the brakes.
I've not much idea what i am doing and was wondering if I'm missing something simple and obvious before i start taking things apart, that i probably can't put back together ha.
Thank you
si_c
Wirral
I don't think that's a disc brake, it looks more like a hub brake, I'm not familiar with shimano Nexave stuff so I'm afraid I can't be more help. @mjr might know more.
  • Like
Reactions: C R
mjr
It's actually a so called roller brake. Part way between a hub brake and a disk brake IMO
The removal "trick" is the same as on many brakes: slacken the adjuster and squeeze the brake arm until you can unhook the cable. I'm surprised they needed a small spanner in the video @screenman posted, but those adjusters are exposed to road dirt so aren't the nicest things to grab and can get stuck easily.
M
mstaves
Ha shows how much i know. Thank you so much i may find a help video on it now x
M
mstaves
You guys have been so much help. Thank you so much. I'm sure i now have the right information to be going on with. Totally appreciate your time and knowledge.
I don't know how to tag people into this response but thanks to yourself, si_c and screenman xx
