I'm not about to start major fettling on the bike for tomorrow's ride.Tell me you're not about to start major fettling on the bike for tomorrow's ride...
From which, and the 0.1mm difference (less than 1mm over the whole range), I think I take that it might not be perfect, but it's good enough.tarting with Shimano, this could be the simplest section of them all if we could just talk about everything up to 9-speed. Basically everything Shimano did up until then was cross compatible. They used a derailleur shift ratio of 1.7 on everything. While the cable pull varies from 8-speeds to 9-speeds as they moved the sprocket pitch closer together, the derailleur remains the same.
8 speed ahifters/7 speed drive train work perfectly well together. Ive been running it on my Trek hybrid for several years.Is an 8 speed Shimano shifter going to be compatible with a 7 speed derailleur and chain? A well-known online retailer doesn't admit to 8-speed derailleurs.
Nearly all Shimano mechs give the same movement for a given cable pull, so that will not be an issue. It is the cassette spacing that has to match the shifter cable pull. For example, an 8 speed shifter will give the wrong amount of cable pull for a 7 speed cassette. If you have an 8 speed shifter and an 8 speed cassette it should be fine.Is an 8 speed Shimano shifter going to be compatible with a 7 speed derailleur and chain? A well-known online retailer doesn't admit to 8-speed derailleurs.
Depends on how many chains you've gone through on this cassette and indeed if the cassette is showing signs of significant wear. You can usually go through 3-4 chains on one cassette before needing to change the cassette as well.I've just realised. New chain means new cassette, doesn't it?
