uclown2002
- Harrogate
I ride most days and invariably the bike is dirty and wet when I return. I try and give it a quick clean after each ride but I'm reluctant to spend too much time on it. I do give it a more intensive clean about once a week if required.
My 10 minute quick clean consists of a fine spray down with a hosepipe being careful to point directly to headset and bottom bracket for eg.
Chain and Cassette (and other oily areas) get dried off with an oily rag and I'd normally use a cleanish towel to (quickly) dry off the rest of the bike.
To finish off I'd normally spray cassette and chain with GT85, before putting the bike away. Every 2-3 days I lube the chain with a better lubricant.
Is that good enough or should I be using a proper chain lube daily?
Anything else I should be doing?
