Do you mean that you used to have three click positions (little ring, middle, big) and now you suddenly have four ?
If so, I don't understand. You should always have had four.
Ultegra has one position for the big ring at one extreme, one for the little ring at the other, and two in between both for the middle - the 'trim' positions, which move the front mech slightly in or out, not enough to actually change rings but enough to stop the chain rubbing.
This allows you to set it up to use the left 3/4 of the block in the middle ring in one trim position but when you go over into the other 1/4 the chainline means it'll start to rub on the front mech, so you can move it over into the other trim posistion which allows you to use the right 3/4 of the block.
Obviously you only have trim for the middle ring, as you don't cross-over and use the whole of the block in either big or little rings.
