@Oldbloke, I did similar with my XC hardtail bike going from a 2010 100mm Fox 'whatever' to a 2019 120mm Reba.
On the assumption that the Reba you're looking at will fit, ie steerer type, axle etc then as said above it will lift the front end, handle bars and bottom bracket, shorten the reach and slacken both the head tube and seat post. Magazines and online 'experts' (who have never tired doing so) will tell you of the massively detrimental and noticeable effect it will have on the ride but unless you are pushing the limits of physics I very much doubt you'll notics a few degree or mm change here and there.
However to keep my geometry factory, I fitted a -2 degree 'slackerizer' headset that put all the geometry back to standard except head angle, and in doing so kept the overall geometry more in keeping that found on modern bikes. The current trend is for 'Down Country' bikes which essentially are XC bikes tweaked to descend more confidentially yet still climb well by having longer travel (up to 130mm) and slacker head angles than pure XC rigs... which mine has been doing for the last couple of years
The total head angle degrees is now 3 degrees slacker going from 70 to 67, with the headset slackening by 2 and the longer forks accounting for the other 1 degree.
If you have the geometry figures for you bike then have a play
https://bikegeo.muha.cc/ and see how much going to 130 will affect it.
I was lucky and 2 degrees was what I needed so I could use a Superstar components slackening headset -
https://www.superstarcomponents.com/en/shop/mountain/mountain-controls/mountain-headsets/. However Works Components doing ½ degree increments
https://www.workscomponents.co.uk/
All of the above is pretty academic as sag, compression, rebound, tokens, tyre pressure, rider weight and position (and speed) will have have a bearing on kinematics once you're in motion
Before...
After...
