I'm still restoring a 1950's BSA girls' "Airborne Bicycle". By a stroke of bad luck the paint sprayers have lost the bottom-bracket (BB) spindle, lock-nuts, cones and bearings, bless them. The bottom bracket shell is 56.5mm long (most old bikes have BB shells of 68 or 73mm, I believe). The internal diameter of the shell is about 34mm, which I think is near enough standard. I reckon the chain line is 36.5mm and from this, if I work out the overall length that the spindle / axle needs to be it is 120mm, near enough, assuming symmetry of the pedals / cranks each side of the frame. I've fitted a period 3 speed Sturmey Archer hub, by the way - a departure from the single speed hub that was originally fitted, but that hasn't altered the spacing between the rear forks or the chain line.
A question arises; if I try and alter an oversized spindle, should the cotter-pin recesses in the spindle be equally spaced either side of the centre-line of the frame? I would have thought so because one wants the pedal crank arms to clear the chain stays by the same amount each side.
I only ask because every old spindle I come across has different spacing from the bearing "cones" to the cotter-pin recesses each side. That would make sense if there were 2 or 3 front sprockets, but where there is only 1, why would the spacing need to be eccentric?
Apologies if this is all obscure techno-babble but I'm learning as I go along. Anybody know what I'm banging on about?
Toodle pip,
Paul
Toodle pip,
Paul
