ColinJ
Puzzle game procrastinator!
- Todmorden - Yorks/Lancs border
I think that a bearing in my Mavic Aksium front hub might have failed. A couple of rides ago I was doing about 40 mph on a long descent when I went over a small bump in the road. There was a clunking sound immediately followed by a vibration in the front of the bike and an alarming graunching, screeching sound!
I stopped as quickly as I could to investigate. I was suspecting a front puncture, a loose wheel, something jammed under my mudguard etc. In fact, I could find nothing wrong! The wheel span freely with the front of the bike lifted. I concluded that a piece of debris had probably been trapped between the mudguard and the tyre and had been ejected before I could stop.
Unfortunately, I have had the problem again 4 or 5 times since. It has always been on fast downhills and it is very scary!
If it were a permanent problem then it would be easy to track down but the intermittent nature of it has me baffled.
Can, for example, a cracked ball bearing manifest itself in this way?
I did notice a small amount of lateral play in the wheel when I had a quick look last night. Could the bearings just need tightening up?
I haven't worked on an Aksium hub before but I think they use sealed bearings.
I can swap in a spare wheel for now and if the problem goes away then that really would suggest that the Aksium hub is to blame. If I put new bearings in then I will do a post mortem examination on the old ones.
