JustT
Regular
- Rossendale
Hi guys,
So a bit of a question, you've probably heard it all before, but here goes. Well after reading lots of topics and threads I desided with Helvellyn looming and all to try out this spinning malarky. Usually I 'grind' (think thats the correct term) up hills in as high a gear as possible, only switching down when I have too.
Now as I gather the idea of spinning is to use as lower gear as is necessary to get up the hill at a reasonable speed without expending as much energy, ie having to get out the saddle as I often do. And keeping a cadence of between 80-100 id ideal.
So after a nice 40 mile flat ride in Cheshire on thursday to give my legs a brake from the hills, I tried this technique out on our local hills on Friday. Now time wise there was not much diference. But 'oh my god' my legs. Appart from 2 sections where I droped to a cadence of 64 I managed to keep it up to 84ish on the hills and 90-101 on the flat. Difference being I had to swap into the small chainring for the hills. And my friend had to wait for me, and thats not happened for a long time. I expected some complaining from my legs, different muscle group usage and all that, but not quite so much discomfort.
So question, am I doing it wrong? Will it make me better on the hills over longer distances? Should I keep at it starting with shorter hill rep work? Or should I just stick to what works for me? And do I have the cadence ratio right?
Cheers
Cheers
Hence my attempt of humour in my reply
