Pumping up tyres - how do people achieve 100psi ?
mikeyw
I recall when collecting my new Trek 1.2 the guy in the shop saying the tyres are likely to leak air quite quickly as they need to run at 100psi :ohmy:
I have noticed the pressures have dropped over the past week and so have tried inflating them, 1st I used a standard mtb pump....not a chance struggled to get any more air in. Next up was a pump compressor I use on the car.....the attachment that best fits the presto wasn't ideal but did seem to put some air in although at about 60psi it could really get any more in.
How do other people go about this ?......is a £25 foot pump the only option ?
TIA,
Mike.
Pearson72
Norwich
Buy a track pump!
PaulSB
Get a track pump for £25-£30 and you'll wonder why you didn't buy one years ago. I also quite like the pumps that fold out into a "track pump style" which you can acrry on the bike.
Cranky
West Oxon
Yep, a track pump for home and - in my case - a Topeak Mountain Morph on the bike (the Road Morph is basically the same).
With some presta-type tubes it helps to let some air out first before you pump any in as they can stick shut after a while.
swee'pea99
Ie, loosen the valve and tap it. One brief Pfffsht is all you need.
+1 for a track pump. Check ebay.
LLB
Another +1 for a track pump
Make sure it is a metal bodied one - you get what you pay for.
swee'pea99
Yeah yeah, they always say that! I got a resin one off ebay for £15 incl del three years ago - it's been fine.
MajorMantra
Edinburgh
+1 for track pump, but you needn't even spend £25 (though you'll get a better one if you do). If you live near a big Tesco (Extra) they do one for around £13 or so, sometimes less. While your there you can pick up the Cree torches that you know you really want.
Matthew
peanut
its not the body that needs to be metal necessarily Its the pump piston rod and top T handle that needs to be metal/robust.
I'd recommend the Wrench Force track pump .It has a solid metal pump piston rod and handle which are unbreakable and costs about £10.00
http://www.bionicsports.com/acatalog/floor_pumps.html
shop around as these go for £10.00 on ebay and other places
LLB
Stand corrected and agree with this. Mine is one of the Red steel ones from Halfords for about £20.
byegad
NE England
To the above I add a CO2 inflator. Hard tyres away from home in seconds and no sweat.
