colin-java
Regular
Hi, I have a 29 inch wheel Mountain Bike...
The valve is a schrader value.
I'm using an older style pump with the little tube that screws onto the innertube valve on one end, and pump on the other end.
The problem is, when I screw the tube onto the innertube value (all the way down), it still keeps leaking air.
Normally it leaks for a couple of seconds while you are screwing it down, but mine just leaks till it goes flat after putting the tube on, so I can't get a decent pressure in their (unless I use the air compressor).
I've tried the newer type pumps that just clip on to the valve, but I've never had much luck with them,
Any thoughts about what I can do here, thanks.
