Hi But hope this the right section to post this question, After suffer more punctures than I would like I was down to my last spare tube put vittoria latex tube in (bought this tube in a moment of madness) though having put it in the tyre And guess what with my ultralite track pump nomatter what I did to support the pump head assemby I could only get about 30psi in the tube, had to get to about 60psi with a 150mm Lesyne pump which is able to be screwed securely to the tube Valve I know the those double headed fittings are perhaps suspect With the schrader and presta fittings see the pictures enclosed. Has anybody else experianced these problemsOr perhaps point me to a more relable fitting for my track pump Thanks
I had latex tubes many years ago, no problems pumping them up, though they don't hold air like a 'normal' tube and need pumping after most rides.
The only obvious thing I notice, is that you haven't unscrewed the valve thingy*?
If not faulty valve...
*The air pressure in an inflated tire holds the inner valve body shut. A small screw and captive nut on the top of the valve body permits the valve to be screwed shut and ensure that it remains tightly closed.
The nut must be unscrewed to permit airflow in either direction. The screw remains captive on the valve body even when unscrewed fully; it is tightened again after the tire is inflated and the pump removed. The valve cap protects the valve body, keeps dirt and mud out of the mechanism, and also prevents the valve from damaging the tube when it is rolled for storage, but is not necessary to prevent pressure loss
